Ir 8500 problem
  • Brucere99
    • Oct 2009
    • 15
    Ir 8500 problem
    We have an refurbished ir 8500, copier has a light background tone. All coronas are new, new drum, developer unit rebuilt, fuser rebuilt. Please help!
  • SCREWTAPE
    • Aug 2025
    What about test pages.
    How does a PG4 look like?
    Or are these copies made from the glass.
    If so,make sure the optics are clean and also the white plate and do a CCD adjust.
    • Brucere99
      • Oct 2009
      • 15
      Ir 8500
      Pg 4 has a background tone top and bottom, middle is lighter.
      • davidj7
        • 1107
        What kinda toner do you use, original or OEM?
        a machine is only as good as your tech : source:screwtape ; the scary one
        • Brucere99
          • Oct 2009
          • 15
          ir 8500
          Canon gpr-7
          • SCREWTAPE
            • Aug 2025
            Is potential control on or off.
            • 20YRSEXP
              • Oct 2008
              • 281
              With everything you've replaced I might start suspecting the laser. If you have one on hand try it out.
              Is the glass half full or half empty? I say neither. The glass is obviously full, full of potential. The potential to hold more water or the potential to quench a thirst. Life is all about how you see it.
              • davidj7
                • 1107
                could you post a scanned image of the problem copy/print
                • FlTech
                  toner save
                  Check to see if toner save in on. Service mode - copier/option/body/cotdpc-d = 0
