canon ir3300 tray keeps lifting
  • nick_schmidt
    • Jun 2009
    • 31
    hello all!!
    ive got a canon ir3300
    tray 1 keeps trying to lift and makes a knocking noise
    there is paper in the tray
    any idea's?????
  • kuby
    • Oct 2007
    • 1371
    sounds like either one of the springs is broke on the
    PAPER PICK-UP MOUNT ASSEMBLY
    or one of the FB6-2778 ratchets is broken.
    very common
    • nick_schmidt
      • Jun 2009
      • 31
      thanks very much
      I'm going to check it out now!
      • nick_schmidt
        • Jun 2009
        • 31
        ive got the feed section pulled out and i cannot find what you were thinking
        any further idea's????
        • nick_schmidt
          • Jun 2009
          • 31
          found a spring that came off the tensioner for the drive belts
          putting feed back in to test
          thanks all
          • ajeet
            Originally posted by nick_schmidt
            hello all!!
            any idea's?????
            the upper trays lifter gear broken thats why noise is coming
            kindly replace it.
            • mrfixit51
              Lead Service Technician
              • Oct 2008
              • 1975
              I have attempted to get in and repair these in the past, and found it to be no fun at all. If you have access to a machine in the warehouse, you could get your "organ donor" parts there. Otherwise I would advise that you replace the paper feed asm as a unit. At least have one as a backup, should you want to try to repair this issue. Bottom lifters are supposed to be fairly straightfoward to repair,,, but my luck has always presented the upper cassette lifter as the culprit...
              have fun!
              • copymon
                • 39
                Make sure you tell the customer / user to stop slamming the paper trays shut, that's usually the cause of the damage.
                • angelntx
                  • Aug 2009
                  • 62
                  Nick,
                  I've worked on this model alot. The 2 parts that wear out eventually is the Gear Ratchet (FB6-2778-000) and the Claw Lifter Arm (FB6-2789-000). Replace them at the same time when you do, it avoids having to go back in there again. The parts don't cost alot it's just time consuming but once you get the hang of it you can do it in under 40min.
