Ir 7095 showing error E110-0000
  • nickkei
    • Mar 2009
    • 20
    Hi guys,
    I have been facing a problem with Ir 7095 showing Err E110 -0000,
    I have tried resetting the error n also clear the mn con but it
    still dun give any cure,
    Help.....
    lost
  • MrB
    • Nov 2009
    • 147
    Sounds like 1 of 2 things it could be
    1) There is Primary Corona cover actuates Laser Shutter on these products. If you run the machine with it off you will get E110!
    2) If the above fails, and still getting E110, sounds like it could be the laser unit
