canon IR1600 laser unit problem
  • s_asade
    • May 2025
    copy quality at one end of paper ( about 5cm ) is very poor. after changing new laser exposure system which has laser unit and 6 facet mirror, the problem is solved. can we repair the laser exposure system, and what part of laser exposure system is affected? plz guide
  • SCREWTAPE
    • May 2025
    My two cent's
    No!
    • logonjim
      • 136
      cq ir1600
      You never said if you cleaned the laser mirrors .That is the first thing that I would do b4 i would change it, and yes dirty laser mirrors can effect the copy quality
      • s_asade
        laser unit problem
        yes i have cleaned the mrror, but no result. what will be the cause for affecting the quality of upper side only?
        • meme
          • Jul 2009
          • 10
          cleaning scanner mirror
          hello.
          but did you clean the polygon mirror thats the cause of the poor quality.
          • s_asade
            yes i have cleaned polygon mirror also.
            • sweet.persona
              Engineer
              • Nov 2009
              • 415
              i was have this problem it is the mirors are not cleaned check and u see the difirence
              A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
              DAMENE ABDEL AZIZ
              DJELFA
              • CanonHPTech
                • Apr 2007
                • 235
                Most problems with image quality on this machine involve the Drum and Developer. If Drum has worn edge (yellow, not green OPC coating) on same side as your image problem, or if you remove drum and pull out developer and look at amount of toner on developer cylinder is light or has all of void lines on the side that your image defect is on, than start there. Good luck. Please post your results.
                The glass maybe half full, but less is more...
                Printer + Fax + Copier = Jack Of Many Trades,
                but Master Of None
                Color Copier = Not A Color Printer
                InkJet MFP = Not A Fax Machine
                B/W Copier = Not A Press
                Finisher = Deal Closer (salesman, not accessory)
                Copier Tech = Admin's Stress Ball (Scapegoat)
