Canon IR C6800 De-installation
  • cdog530
    • Nov 2009
    • 66
    We are a Ricoh dealer and another company wants us to prepare a Canon IR C6800 for shipment. I know someone on here can probably give us an idea on breaking this machine down for shipment. Approximately how long it takes and what needs to be done....so we can give an estimate. I appreciate any input..
    Thanks,
    Cdog
  • SCREWTAPE
    • Aug 2025
    Thanks,
    Cdog
    Mosty the developers and toner should be taken out. I would get a service manual if I was you. It does not take long but then again I refering to how long it takes me. If you have never done it before get a manual.
    Good luck.
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      Just place the entire machine in the shredder,, and hold down firmly on the go button..... sorry,, I just could not resist that..
      • SCREWTAPE
        • Aug 2025
        I kind of agree with you Fixit.
        If Cdog only knew how much I emphasize the words "GOOD LUCK"
        Hey Cdog its not that we are trying to discourage you
        But good luck!
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          Take the reader unit off and pack separately as well...if it's transported by road the lid may bounce and smash the platen glass....oh...AND GOOD LUCK..!!!!
          • trainman6446
            • Nov 2009
            • 10
            I feel sorry for the recieving dealer.
            If you have never worked with this mchine before, get an authorized canon dealer to do it.
            • CanonHPTech
              • Apr 2007
              • 235
              At very least, if has a Finisher, it should be separated from machine. Also, all cables going into machine should be disconnected and all decks/cassette should be opened than closed to drop the lifters. However, if you want to do it the right way and are worried that this machine will start printing rainbows when it is set back-up, then the developers and toners should be be pulled. However, if you've never done it, it will take close to an hour and has a lot of room for error. I would pass on it, because it sounds like you will end up buying someone a new machine.
              The glass maybe half full, but less is more...
              Printer + Fax + Copier = Jack Of Many Trades,
              but Master Of None
              Color Copier = Not A Color Printer
              InkJet MFP = Not A Fax Machine
              B/W Copier = Not A Press
              Finisher = Deal Closer (salesman, not accessory)
              Copier Tech = Admin's Stress Ball (Scapegoat)
