IR4570 display flickering
  • mikeytech
    • Sep 2009
    • 6
    Hi guys
    Have a flickering display on 4570 and when it does flicker you get no response from the ikons on the display. I would try ordering a new display but they are so expensive Any ideas please?
  • SCREWTAPE
    • Jul 2025
    Originally posted by mikeytech
    Hi guys
    Try reseating connectors if and when you try removing it.
    Sometimes it is what it is.
    • mikeytech
      • Sep 2009
      • 6
      re ir4570 display flickering
      Hi all
      Turned out to be DC Controller but having replaced that it has changed the meter reading from 16k to 684k which i don't understand. Any ideas.
      • THUK
        • Jul 2008
        • 195
        hi,did you not swop over the counter pcb.
        • mrfixit51
          Lead Service Technician
          • Oct 2008
          • 1975
          Did you swap out the DC Controller or the Main? The counter board is mounted on the Main Controller.
          • mikeytech
            • Sep 2009
            • 6
            Yes it was the DC Controller and i did change the counter pcb and that is why i'm confused.
              If you changed the DC controller you would have no need to change the counter as it plugs into the main controller. As far as I know if you take the counter from one machine and place it in another the machine becomes unusable and gives a 354 error which cannot be cleared.
              • mrfixit51
                • Oct 2008
                • 1975
                I'm confused too...
                As I stated in my previous question to you,,, the counter board resides on the Main Controller. Changing the DC Controller does not require you to touch the Counter Board. Why would you swap the counter board??? What were you hoping to do by doing so?
                • mikeytech
                  • Sep 2009
                  • 6
                  mrfixit51 i'm aware the counter pcb resides on the main controller, i obviously didn't make myself very clear. The only reason i swapped the counter pcb over was because when i replaced the dc controller thats when the reading changed and i couldn't understand why.
                  • waffu22
                    • Jun 2009
                    • 95
                    Changing only DC controller board and not removing/replacing the counter board it would not change the counter. I did it many times and not happening on my machine.
                    • bluemax121
                      • 19
                      ru sure the panel bord connections perfact is it no
