iR5000
  • waffu22
    • Jun 2009
    • 95
    iR5000
    Hi to all the readers
    iR5000 machine starts with an error 0004 - 0001. My operator did not turn off the machine and leave it open ( 1 hour ). When i go to on svc mode to clear the error, when i ON the machine, its in WAIT mode.
    Any ideas?
    Thanks...
  • shazza
    • Nov 2009
    • 96
    Hi,
    Check thermistors and lamps H2 Fuser lamp may of blown
    (REPLACE FUSER LAMP P/N FH7-4552). Also make sure staple cartride not empty! May sound strange but had same problem on a 7105
    Shazza
    • trainman6446
      • Nov 2009
      • 10
      also try cleaning the fuser contacts on the fuser frame assy
      • waffu22
        • Jun 2009
        • 95
        Originally posted by shazza
        Hi,
        Shazza
        I swap the whole unit 1 to other machine and its OK.
        I suspected a bad HD.
        • smiley
          • Aug 2008
          • 615
          hi it can be a bad thermistor.try to replce it and clear the error.
          there is no glory without sacrifice
          • SCREWTAPE
            • Jul 2025
            Check the fixing feeder unit connectors and the ones in the inside rear part of the machine. Make sure that these terminal connectors are making proper contact when you slide it in. Check for jammed packed paper inside of those connectors.
            • mrfixit51
              Lead Service Technician
              • Oct 2008
              • 1975
              "iR5000 is in "WAIT" mode"
              Any ideas?
              Thanks...
              I got hung up on the E004 error code, but I agree that your most likely cause of the wait... is a faulty hard drive.
              • MrB
                • Nov 2009
                • 147
                Could be as something as simple as a scrap of paper inside the fixing unit connector
                Could be as strange as that
                Check both sides of the plug
                (On the fixing unit and the 2nd part of the connector inside the device)
                • waffu22
                  • Jun 2009
                  • 95
                  Your right mrfixit51, its faulty hard drive.
                  Thanks for the reply guys
                  • angelntx
                    • Aug 2009
                    • 62
                    Anyone bother to check the thermoswitch? If the coating gets worn off you will see this code.
                    • costd
                      • Jan 2008
                      • 409
                      Normally something along the lines of "Your right mrfixit51, its faulty hard drive" means the issue was resolved.
