Canon iR2270 will not print
  • patk
    • Jun 2008
    • 56
    Trying to set this up on small LAN .
    I have installed UFR II and PCL drivers on XP PC and all looks OK. Canon is found by driver install program, I can ping it and Remote UI comes up as normal. But test copy will not print. Spools on the PC and never prints.
    So have tried all of following:
    1. Installed driver on laptop and connected via crossover cable- Same result
    2. Connected laptop via USB- same result ( Can see data light flash on Canon, "printing" comes up on control panel but nothing outputs. Log has NG #853.)
    3. Checked HDD, formatted HDD, reseated memory on print PCB, reseated all connectors
    Would be pleased to get any advice
    Cheers
    Pat
