patk11-18-2009 06:09 AM
Canon iR2270 will not print
Trying to set this up on small LAN .
I have installed UFR II and PCL drivers on XP PC and all looks OK. Canon is found by driver install program, I can ping it and Remote UI comes up as normal. But test copy will not print. Spools on the PC and never prints.
So have tried all of following:
1. Installed driver on laptop and connected via crossover cable- Same result
2. Connected laptop via USB- same result ( Can see data light flash on Canon, "printing" comes up on control panel but nothing outputs. Log has NG #853.)
3. Checked HDD, formatted HDD, reseated memory on print PCB, reseated all connectors
Would be pleased to get any advice
Cheers
Pat
Hi Pat,
Are you certain that this box is print enabled? The network port does not mean that it is good to go. You can get to RUI, and ping the beasty without a print kit installed. If you check your Counter button on the op panel, and click on installed options on the bottom of the panel you can see what features have been installed. You need to look for UFR, PCL or PS versions if it can print.
Cheers
Pat
Hi Pat,
