System error E000
  • Hussain Habibzadeh
    System error E000
    hi, my copier (canoon IR 1600) shows : System error E000
    how i can solve that problem?
    Regards,
  • CanonHPTech
    • Apr 2007
    • 235
    Hello, sir. E001 is a high temp. error. My first advice would be to atempt to clear it in service mode:
    1. Press ADDITIONAL FUNCTIONS, #
    2. Go to #7 Printer and press OK
    3. Go to #4 Printer Reset and press OK
    4. Yes = ( * )
    5. Power cycle unit.
    If this does not help, on most units you have to start looking at your Fixing Assy. or Thermistors. Make sure that you do not have a piece of paper wrapped around Upper Fixing Roller or and other foreign substance in that area. However, on this one, I would recomend replacing Fix Assy. as a whole if you can, FG6-8326-000 (for s/n starting with MQT/MQV/MRV/MRW) or FG6-8325-000 (for all other s/n). Don't see p/n for Thermistors. Also, heard of alot of other board and p/s issues with this model that can cause E001-E004 errors. See if you can clear it first. Good luck. Let me know how you make out.
    The glass maybe half full, but less is more...
    Printer + Fax + Copier = Jack Of Many Trades,
    but Master Of None
    Color Copier = Not A Color Printer
    InkJet MFP = Not A Fax Machine
    B/W Copier = Not A Press
    Finisher = Deal Closer (salesman, not accessory)
    Copier Tech = Admin's Stress Ball (Scapegoat)
    • bimonoo
      I have also this problem.
      Can you help me
      • eng_nsour
        • Nov 2008
        • 10
        solution 4 e000
        hi
        i got this error b4 e000 means low temperature so you have a problem in the fuser unit>
        check thermo lamp, thermistor in the fuser unit and then reset the machine.
        i advise u to visit CANON PHOTOCOPIER UK Error Codes
        • zaza
          MECANOGRAPHE
          • Mar 2008
          • 1095
          hello technician
          Originally posted by eng_nsour
          hi
          hi technician ...hi friend technician hussain did you need service manual of this copiers ..canon ir 1600
          BEST TECHNICIAN . NICE PEOPLE .
          • jummamaster
            • Mar 2009
            • 99
            Re: System error E000
            E000 reset procedure for 15 popular Canon machines.
            Ricoh Error Codes
            Canon Error 5100
            Canon Error B200
            j
            c
            • jummamaster
              • Mar 2009
              • 99
              The above mentioned link is dead now. Updated link is here:
              E000 Reset Procedure
              Ricoh Error Codes
              Canon Error 5100
              Canon Error B200
              j
              c
