iRC2550i black print in half tone
  • yukisum
    • Jun 2025
    I was facing this technical issue. I had change the toner motor & new black drum but the problem still could not resolve. Anyone had been facing this problem before?
  • victor_v
    • 71
    What for the device iRC2550? I from other region...
    Anyway, it seems to me that developer units not densely adjoin to a drum. At me the similar picture turned out on iRC3100 (have forgotten to remove lateral shipping consolidation).
    Scans 2 and 3... Obviously badly works cleaning blade. In this case on a copy can be anything you like.
    I would eliminate at first these problems, and then already would operate on circumstances.
    Hardworking people are not present. Simply many it is boring to idle.
      The first picture looks like a problen with the charge roller in the black drum. There's quite a lot of conductive grease on the ends of the charge roller. I had a similar problem when replacing a drum, getting all this grease over my fingers and not thinking about it just reassembled the drum.
      • mrfixit51
        Lead Service Technician
        • 1975
        First image problem could be caused by primary transfer roller in the ITB for black. Not secondary's because other colors unaffected. Last two pictures look like a black drum issue.
        • D_L_P
          Self Employed
          • Oct 2009
          • 1196
          I agree with MrFixit, if you tried a new drum and had same issue look under the ITB belt and try a new drum for the 2nd and 3rd images. I have gotten bad ones right out of the box.
          At first I thought the second and third image looked like when someone adds the wrong toner, but copiers nowadays are engineered to avoid that.
