IRC 1021I
  • meme
    • Jul 2009
    • 10
    IRC 1021I
    hello.
    my costumer have a irc1021i ,and i wanted to install scanner by network ,scangear tool is installed but by SMB protocol it doesn t work can it work with the XP HOME EDITON.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Originally posted by meme
    hello.
    hello Meme:
    you dont need to install scanner.On your PC create a share folder and on your copier go to "scan to directory"enter username and password and find your folder.Also you must use SMB protocol.For network send you dont need
    scangear tool.
    • meme
      • Jul 2009
      • 10
      yes,but do you now if with the xp home edition it works,because i did what you said and didn t work,because in the properties of the folder it doesn t appears the security and i cant give full controll to everyone.it give always the same error #753 (it doesn t if the folder or the computer).
