Last copy Jam in IR3300
  • sense8
    • 6
    i have IR 3300i. color display
    every time in a set of copies the last copy is jammed in the exit unit.
    eg . in 10 copies the last 10th copy.
    in the case of a single copy will be also jammed
    the machine don't have a finisher.
    i had checked by replacing the exit unit, fixer unit.
    give me a solution.
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    Did you replace the Fixing film assembly or the whole fuser unit?
    Check the exit sensor on the fuser (Parts manual Figure Q810 part #22). That flag sticks or has a weak/slow return and causes jamming.
    • sense8
      • 6
      i had checked with whole fuser unit
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        Jam codes please
        • CanonHPTech
          • Apr 2007
          • 235
          If you have an internal finisher, your issue probably resides in a weak spring for the flag in the tray. As the paper gets pulled back, it presses on a flag. If you can push this flag by hand and it sticks or slowly returns, this is you issue. Usually jams more on long paper like LGL and 11x17. Let us know.
          The glass maybe half full, but less is more...
          Printer + Fax + Copier = Jack Of Many Trades,
          but Master Of None
          Color Copier = Not A Color Printer
          InkJet MFP = Not A Fax Machine
          B/W Copier = Not A Press
          Finisher = Deal Closer (salesman, not accessory)
          Copier Tech = Admin's Stress Ball (Scapegoat)
          • bineeshgeorge
            • Jul 2009
            • 107
            You just take a copy with the semi locked left side door. (do not lock the door completely)
            good luck................
