Need the most important things to do for installation of this machin.
need help of iR3225 installation
Plug in machine, flip power switch, put originals in ADF or on Glass, your choice, and press Start. Joking aside, depends on what you are doing. The only real setup for these machine beside normal stuff (paper type in trays, etc) is configuring to print or scan. If it is coming new from Canon, then you will have to install toner, Drum and accessories. Please be more specific. Just a tip, customer usually dictates what they want to be setup on install. If they don't, but they say, "I don't have authority to make that decision" or "Our manager is out of the office today, she would have all the questions. Today is not the best day. She will be back next week," you will live there regardless for the first few weeks configuring, reconfiguring and training. Good luck.The glass maybe half full, but less is more...
Printer + Fax + Copier = Jack Of Many Trades,
but Master Of None
Color Copier = Not A Color Printer
InkJet MFP = Not A Fax Machine
B/W Copier = Not A Press
Finisher = Deal Closer (salesman, not accessory)
Copier Tech = Admin's Stress Ball (Scapegoat)Comment
iR3225
To davidj7: good joke, but most of machines i had service are Kyocera, Xerox, Sharp. For example there are simulations for initializing toner e.t.c.
To CanonHPTech: special thanks! You have wide experience in studying habits of the customer:-)Comment
