E000604-001 iRC3220
  • sgcopiertech
    • Jun 2025
    E000604-001 iRC3220
    machine originally came with an imagepass c1 printer server installed
    I removed the c1 and want to use the PS/PCL settings.
    I replaced the open interface board with the UFR board
    I replaced the C bootrom with an N bootrom
    installed new system software.
    now when i reboot the machine, E604-001 comes out.
    however, if i put back the C bootrom, the error code will not appear.
    E604 only comes when I use the N bootrom which made me think that the
    is SDRAM is ok.
    anybody who can point out my mistake? suggestions? thanks!
    What happens if you use the n bootrom with the open interface board installed ie take out the UFR board?
    Did you also go to service mode / option / img-cont and set this to 0
    • sgcopiertech
      img-cont was already set to 0
      but i didn't get the chance to test the N bootrom + open interface board.
      I managed to make the thing work, while reading the service manual
      I stumbled unto this phrase:
      "Be sure to use the image memory (SDRAM) PCB and the boot ROM from the old PCB on the new main controller PCB."
      so I took the memory from the same machine I took the n bootrom from and suddenly...it works?
      I'm pretty sure the previous memory is ok since it doesn't cause any problem when I'm using the C bootrom.
      although the machine is working now, I'm still confused
      • ymmtech
        • Jun 2009
        • 191
        Boot Rom check RAM modude SEEPROM data.
