Waste ink reset on MP190
  • DadO
    • Dec 2007
    • 401
    I don't know the procedure for clearing waste ink count on MP190 (not the MPC190 ).
    Thx.
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    This is for an MP145 but it should be the same procedure for other models:
    These are the step How to Reset waste ink counter (error E16) :
    1. Turn off power button (power button is in ),
    Press and Hold STOP/RESET then Push ON/OFF button
    2. Hold ON/OFF button, press STOP/RESET button 2x
    3. Let go of both buttons and printer is in SERVICE MODE
    4. Printer will be readying
    5. After printer is ready, push STOP/RESET button 4x. (Waste ink counter reset)
    6. Every time you push STOP/RESET button ,
    ON/OFF lamp will change green and orange.
    7. cycle power
    • DadO
      • Dec 2007
      • 401
      I am in service mode and i see displaying "0" but when i press stop/reset button 4x time i can't see change on lamp. I cycle the power but E27 continue to display.
      Thx oze on help
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        Apparently THIS is the fix:
        Reset Waste Ink Canon MPC190 :
        1. Press MENU COPY SCAN COPY COPY
        2. This will take you to TEST MODE
        3. Use the + key to take you through to PRINTER TEST (option 8)(if you go past, either keep keying the +, or you can use the - to take you back)
        4. Ensure that it shows 8-3 on the screen. This is EEPROM CLEAR
        5. Press OK
        6. It will show 0 INK COUNT
        7. Press OK
        8. Press the STOP/RESET button
        9. Press the ON/OFF button
        10. The printer won't turn off, but will "reset" itsel
        • DadO
          • Dec 2007
          • 401
          This is MP190.There is no C letter . I tried fix when printer is still warming up and when it's in E27 state. I always get e27. I tried both ways more then few times. This works for MP"C"190 but not for my MP190.
          • amuba
            • 30
            7. cycle power
            ------------------------------------>solusi reset permanet download for Do it yourself Inkjet and Laser Printer Repair
            • vaclav borc
              • Jan 2008
              • 75
              mp 190 usual reset not work
              Thx oze on help
