Convert power 110v to 220V
  • kkwong0209
    • 45
    Can we convert power supply for ricoh and canon from 110V to 220v? What the equipment i need? is it the cost expensive? Its will be stable after convert?
  • infomaxbs
    Trouble Hunter
    • 29
    step down 110 coverter
    there is a step down converter available which converts 220 V to 110 v, no need to change power supply and other lamps for this purpose
    Failures is the knowledge bank of experiences
    • costd
      • Jan 2008
      • 409
      Make sure you do not have a 60Hz vs 50Hz issue.
      • 10871087
        • Jan 2005
        • 1143
        The voltage conversion is easy, it's the Hertz the Hurts.
        • shout_print
          • Sep 2009
          • 18
          Can confirm no issue running off a stepdown
          Hertz does not seam an issue
          4 months running a 3220 with no issues
          • madu132
            • Dec 2008
            • 65
            I think as long as it already converted to DC, there wouldn't be any problem with frequencies.
            The problem only happen if there are motors that connect directly to AC power supply. because the rotation speed will be affected.
            is there any motor on copier which use direct AC power? maybe the cooling fan?
            • smiley
              • Aug 2008
              • 616
              i got a problem on this i try to put step down transformer on 60hz machine and the only available step down transformer is 50hz ,e003 ocurs.fixing problem and it slows down the machine.
              there is no glory without sacrifice
              • davidj7
                • 1107
                which machine are you using
                a machine is only as good as your tech : source:screwtape ; the scary one
                • smiley
                  • Aug 2008
                  • 616
                  ir 2270
