Canon ir-5070 Waste Toner Full Message
  • wiggersp
    • Nov 2008
    • 13
    We have a Canon ir-5070 displaying "Waste Toner is Full" message. We have emptied the waster toner container & I have tried clearing the message in Service Mode without success.
    Any info on how to clear this would be appreciated.
    Thanks,
    Paul
    There's probably a build up of hardened toner in the waste toner pipe and resistance on the feedscrew inside the pipe.
    • Jules Winfield
      • Jul 2009
      • 821
      Try replacing the waste tank instead of just dumping out the waste toner.
      But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
      • waffu22
        • Jun 2009
        • 95
        Thanks,
        Paul
        I agree what skynet said. You can remove the toner pipe and clean it
        • Brian8506
          • 1665
          Did you clear the count in service mode
          • mrfixit51
            Lead Service Technician
            • Oct 2008
            • 1975
            Brian gets the star His is the best answer.
            • smiley
              • Aug 2008
              • 615
              yup you yave to clear waste toner counter under service mode level 1 in counters.
              there is no glory without sacrifice
              • montana
                • Aug 2008
                • 392
                hi..i advice you to check the sensor of the waste toner bottle..clean it or replace it as necessary ...good luck
