Error: 000120 Canon CLC 2400 Startup Problem
  • signs101canada
    Hi: I have Canon CLC 2400 photo copier. When I turn it on, after start it will show Error: 000120, and will advise to restart the machine. After restart the same messages comes back. Please help
    What is the possible cause, and how to fix it.
    info@signs101.ca
    thanks
  • seeb
    • Nov 2009
    • 41
    An E000 error code has to do with the fuser section. In order to proceed you need to release the code in service mode, power cycle the machine and see if the upper fixing lamp is coming on. If it is, I would then check your thermisters.
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      info@signs101.ca
      thanks
      Just for clarification, would you please restate the error code, exactly as it is displayed on the screen. All zero's and hyphen please. We will be better able to answer your question then.
