Install drum into Canon iRC2380i
  • gfabien
    Hello,
    I was asked my company to install the new Canon iRC2380i copier.
    I installed everything, bins, fax, toner ...
    but I don't know how to install the 4 drums !
    Thank you for your help !
  • phasermajstr
    • Dec 2008
    • 9
    Hello,
    hm quite tricky to explain. You have to open front cover. On the right you have to remove plastic cover. You'll find a handel there with wich one you can unlock the imaging unit. You will have to remove two srews as well - one is nearby the handel inside a small hole, and one on left oposite side, easyer to see. Hope you'll find them.
    Now you pull the whole unit out. You will see a button in ITB belt cover, press it and ITB will pop up. There you'll see docks for drums...
    It would be much easyer to explain this with pictures... Hope this post helps...
