ir5000dn machine not booting
  • karanoberai21
    • May 2009
    • 44
    when i power up my ir5000, the machine does not starts but i can see the power indicator on the control panel. the control panel is totally blank, machine is also not warming.
    i'd tried swapping ram of another machine but it also dont works.
    can any one suggest what should i do.
  • 49994
    wow... u must check your harddisk. The problem may be hardware or software.
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Flash your boot with the correct firmware. If you had a hardisk error you would get a E602. Its definitly hardware or firmware related though.
      • karanoberai21
        • May 2009
        • 44
        the machine is totally blank. i cant see the control panel on it. how can i connect the machine and set it to the download mode in these condition. how can i flash the boot rom if the machine is totally blank
        please help.
        i had tried swapping the two rom one of 128 mb and another of 64 mb. but no result
        • THUK
          • Jul 2008
          • 195
          hi,disconnect the hard drive,ive had hard drive prob b4.
          • karanoberai21
            • May 2009
            • 44
            [QUOTE=THUK;111351]hi,disconnect the hard drive,ive had hard drive prob b4.[/ive aloso tried this one. really getting frustated from it
            • SCREWTAPE
              East Coast Imaging
              • 3396
              please help.
              Its plain to see that your not familiar with the procedure.
              You must acquire service support tool and firmware for a 5000DN. Then you must put the machine in download mode, which it can be done in this circumstance.
              Your best option at this moment is to call a tech. The unit must be flashed.
              • Kapten
                • 52
                One other soluttion
                If the memory is ok. Its special memory you cant use other than original.
                Ive tryed with 3 differnt memorys byt when i tried original it starterd instant
                i think try new firm via sst.
                Once ive had to change the maincontroler...
                Good luck
                • 49994
                  please help.
                  Have your machine an original DIMM-ROM and an original Harddrive??? If u ever changed the dimm rom or the hdd with the other so your problem started from here. if its true, you must replace the original dimm-rom & hdd, and you must flash it by the procedure.
                  • karanoberai21
                    • May 2009
                    • 44
                    DIMM-ROM and Harddrive are original.
                    i also tried swapping ROM, Harddrive, DC Controller and power supply to another machine. everything works fine on another machine. if the problem is in the hdd or the rom, the same should not worked on another machine but its working fine. i also checked the wiring inside, its all ok.
                    im really confused what to do. im not able to get the solution.
                    please help
                    • D_L_P
                      Self Employed
                      • Oct 2009
                      • 1196
                      Originally posted by SCREWTAPE
                      Flash your boot with the correct firmwareIf you had a hardisk error you would get a E602. Its definitly hardware or firmware related though.
                      Screwtape has the best suggestion so far. If you can't flash it swap it with another one. This is the smaller (40 pin?) memory chip, not the 128MB ram.
                      Definitly sounds like its related to your boot rom.
                      • SCREWTAPE
                        East Coast Imaging
                        • 3396
                        If the problem is in the hdd or the rom, the same components should not worked on another machine, but its working fine.
                        So your saying that you take the bootrom and dimm chips from the one machine that has the problem and you put in another machine and it works?
                        Have thought maybe you have a problem with the control panel...
                        • 49994
                          please help
                          please, try change the main board without Dimm-rom & counter chip. use original Dimm-rom, Counter Chip, & Hdd from the machine. I think the main board is faulty.
                          • kuby
                            • Oct 2007
                            • 1409
                            I have to agree with Screwtape on this one. I had a machine that would not boot (nothing on the display). Swapped the memory, boot rom, HDD, etc still nothing. Someone suggested the Display. I took the Display off and gave it a good cleaning and blow out. Put it all back together and it worked.
                            • karanoberai21
                              • May 2009
                              • 44
                              thnks and happy new year
                              thanks to all of u techs. you all helped me in solving my problem. happy new year
