canon ir c3220 printing green stripes
  • said
    hello I have a problem with my printer, it is printing thin green stripes on the right side of the paper. I feed it on the bypass because i use 12x18 heavy 2 paper. I have been working with this paper about 2 months and i had no problems until now
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    Do you have a Fiery controller, or the internal Canon controller?
    I saw this with a Fiery once (same green streak)- reseat the SCSI cable that goes between the Fiery and the printer (after powering everything off, of course )
    Not sure what the issue would be with the internal controller, though.
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Considering you use heavy and 12x18 paper, thin green stripes could be anything, transfer cleaning, drums. I would look at those components first.
        The first thing I would look at would be the magenta drum.
        Have you tried a 'skyshot' using the 3 colours? Raise the feeder and with nothing on the glass go to colour select / single colour then take a copy using the 3 colours. The first thing I would look at would be the magenta drum.
        • roho
          • Mar 2009
          • 844
          Usually when drums fail, they'll start to leave toner on the edge of the page, leaving no blank border. Usually starts to show up after a few prints, the first few may be fine. I suspect yellow and cyan drums are failing-hence green. Running heavy stocks will lower the life of the drums.
