Canon L295 Fax
  • Grasten
    • Apr 2006
    • 9
    Canon L295 Fax
    Am having problem with this fax machine all of a sudden its no longer receive or send faxs. We have a line specifically for the fax only. We tested the line using another fax machine its receiving and also sending.We programmed it (FAX ONLY) so that it automatically receive faxs when it gets a fax signal.
  • Faxguy
    Are you sure your lead is in the LINE socket and is not damaged
    • Grasten
      • Apr 2006
      • 9
      I switched that line PCB from another L295 and there is no improvement.
