irC3200
  • tech_c3
    • Jul 2008
    • 31
    irC3200
    just want to ask on how to disable the reader unit since machine arrived without communication cable between reader and printer. we want to test the printer if it is ok. thnks
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Copier>Option>Body>W/SCNR to 0
    • tech_c3
      • Jul 2008
      • 31
      Thanks,
      But I could not enter to service mode * 2 8 *.
      What are the other ways in entering to service mode?
      • SCREWTAPE
        East Coast Imaging
        • 3396
        Thanks,
        It should work.
        Additional function/2&8/Additional functions.
        Hit reset when it doesn't respond then try again
        Maybe somebody changed it.
        Rather than 2&8 try 4&9.
        But continue with 2&8.
        Were you hitting the asterisk* number key?
        You should be hitting additional functions key.
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          Nope...on a 3200 *2 and 8* is it...persevere...keep trying...the ability to enter service mode is only limited by your clumsiness
          • davidj7
            • 1107
            cant argue with that .Ha HA!
            a machine is only as good as your tech : source:screwtape ; the scary one
            • SCREWTAPE
              East Coast Imaging
              • 3396
              Hey Ozey, Are you sure about that.
              In service mode that option is available for the 3200, SVMD-ENT. Use it to see how to start service mode:0: User Mode key -> 2 and 8 keys at the same time -> User Mode key (default)1: User Mode key -> 4 and 9 keys at the same time -> User Mode key.
              • sgcopiertech
                kabayan, maybe you should check if the buttons are working/responding properly first.
                • waffu22
                  • Jun 2009
                  • 95
                  As what the previous post said keep on trying to hit * 2 and 8 and be sure all the buttons are working properly.
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                    If the machine is being stubborn going into service mode, try resetting the main power switch, then trying it again.
                    Doing so normally helps when this happens.
                    • wingnut132
                      • 65
                      if I remember correctly *4-9* started with the 4570 series
                      • Oze
                        Ricoh Fanboy
                        • Jul 2008
                        • 1663
                        If you have a hand that looks like you have 5 thumbs then do NOT attempt to get into service mode
                        but seriously...remember to hit the reset button after each failed attempt at getting into service mode.
                        • davidj7
                          • 1107
                          hey come to think of it , if someone dosent know how to get into service mode isnt he/she better off not entering. no offence to anyone but thats a tech only place
                          • nivssluck
                            • May 2008
                            • 228
                            I had this problem with my ir105+. I tried all the combination keys on the panel but it didn't work. It seems the 2 and 8 is not working but if you go to safe mode that is turn on the machine then 2 and 8 it works fine.
                            I thought that it's a hard disk fault. So I changed the HDD but still the same.
                            But when I changed the Main Controller, I can easily get through on the service mode (with a smile ) ...but I don't know which part of the main controller has a problem...
                            • tech_c3
                              • Jul 2008
                              • 31
                              thanks to all your posts.
                              srewtape is right, to enter service mode in irC3200: additional function key, 2&8, additional function key.
