canon ir 3300 error #E000202-0001
  • biswa69567
    • May 2025
    Dear Sir,
    I Received a problem canon ir 3300 error #E000202-0001
    PLZ Give me Solution
  • waffu22
    • Jun 2009
    • 95
    This error is related to scanner. Try to clear in service mode (* 2 and 8 *) clear, ERR then OK
    • montana
      • Aug 2008
      • 393
      hi.....as the s-m said...E202-the home position sensor does not go ON.when the main power sw turned on.
      001-the scanner home position sensor does not go OFF.when the scanner moved forward by40mm.
      i hope it is help my dear.i wish you good luck
      • biswa69567
        canon E000202-0001
        Dear sir
        I try it, but copier still does not work
        • canonjh
          • 39
          The following are needed to replace.; Scanner home position sensor, the scanner motor, reader controller PCB
          • D_L_P
            Self Employed
            • Oct 2009
            • 1196
            • costd
              • Jan 2008
              • 409
              D L P gave you the right process. Check the lock first. Then I would Power down, remove the glass, and move the scanner to about half-way (in order to make sure it moves enough for you to notice). While the glass is off is a good time to see if the HP sensor is knocked loose. Put glass back on, power on and observe if the scanner moves and stops before "slamming".
              No movement means either the motor or reader board. Could be either, but the way I would go is Remove the covers so you can touch the motor with your hand, and power cycle the unit. What you are looking for is if the motor is trying to activate (yes guys, I know about part check - but I get the feeling he is more basic than that). No attempt - I would replace the motor first. Attempt but no movement, I would replace the board first.
              If it moves, change out the HP sensor. After changing the sensor - if it still happens, the reader board has an issue.
              As always, your milage may vary
              Last edited by costd; 12-21-2009, 05:33 PM. Reason: Spelling is not my strong suit
              • bineeshgeorge
                • Jul 2009
                • 107
                Originally posted by biswa69567
                Dear Sir,
                First you check the Power, proper voltage and amps.........................
                • biswa69567
                  i cheque it is ok but copier not work
                  • costd
                    • Jan 2008
                    • 409
                    Guess it is up to you, but rather than jumping all over the place checking the least probable cause - why not try the troubleshooting process of the 4 most probable causes (lock, sensor, motor, board) DLP and I suggested? Scanner movement, or failure to move, is key in a 202 error.
                    • jdichter
                      • Oct 2010
                      • 18
                      I just got this error E000202-0001 when I accidentally pulged the copier into a 220 V plug. Heard a nice pop. Unit still powers on but give the error. HELP!
                      • CT Copier Repair
                        • Mar 2010
                        • 304
                        you blew it up
                        at least the power supply or the main board
                        time to trash it the info about plugging it into 220 instead of 120 would have been helpful up front
                        the way you did it was a waste of peoples time
                        get a meter out and start to go point to point
                        if you can't do that then call a technician
