IR3300 Display doesn't come up.
  • bisiawoeyo
    • Dec 2007
    • 65
    Can someone pls help me out.There is this Canon IR3300 copier, the control panel doesn't come up and it doesnt warm-up/initialize.What can I do plz?Tanx in advance.Bisi Awoeyo.
  • Luther
    • May 2006
    • 682
    One of the memory sticks may be bad or the contacts need to be cleaned
    • montana
      • Aug 2008
      • 392
      hi.....remove & reinsert the SDRAM...or replace it
      i wish good luck
      • mrfixit51
        Lead Service Technician
        • 1975
        Do you have the green power light lit up on the front of the panel? If not, check into your low voltage power supply...
        good luck
