IR3300 Toner Not Fixing Properly
  • abkonnet
    • Mar 2008
    • 166
    Hi in IR3300 Toner is not Fixing Properly it stick in Hands. Change the toner brand nothing changed.
  • victor_v
    • 71
    Hi,
    I would check up pressure in a fuser.
    Hardworking people are not present. Simply many it is boring to idle.
    • maks
      • May 2008
      • 75
      just try to get the ORIGINAL TONER....that i think will solve the problem...
      • davidj7
        • 1107
        i would go with maks , use canon toner
        a machine is only as good as your tech : source:screwtape ; the scary one
        • Brian8506
          • 1664
          I would be checking everything in the fuser.
          • montana
            • Aug 2008
            • 392
            IR3300 fixing problem
            hi...check the lower pressure roll it may not in the right position..
            i hope it is help..good luck &happy new year..
            • naveencopier
              • Oct 2009
              • 26
              re place the film and pressur roller
