irc 3200
  • smiley
    • Aug 2008
    • 616
    irc 3200
    hi guys please i need any suggestion.my 3200 after making a few copy the machine stop working the display turns off but the green led still on and when i turn off the machine end turn on i can use the machine again but only few copies.i change the ram and boot rom but still no good. any one inconter this before.please help me.
    there is no glory without sacrifice
  • sgcopiertech
    I've encountered this problem a few times already and most of the time is power supply, check if you can find any dry joint on the pcb and solder accordingly.
    • Alan Aya
      Is there any error code, if there isn't any code, you can try replace the HDD (it can give you this problem). I encounter this problem on iR3300 some times ago.
