If I remove Fiery I do not get any error. I can print a file from control panel that does not go through Fiery, like the P-Print etc.
I had not mentioned the fact but I have a keyboard, monitor and mouse on Fiery so I can see what is going on.
The command workstation toolbar at the top of the screen turns red and says check network cable etc when I turn off the C1. The printer tab on C1 shows the printer and if I turn off Fiery it says "please wait". I am actually sending test files from Fiery directly.
If I use the control panel on C1 and send a file it is seen on the Fiery so I know that part is working but I feel like it is all in the file info not going through the video card/cable to C1.
You said sdram and then memory (dimms), I removed cleaned one dimm that was below hdd,
and the boot rom that was on the right side off hdd.
sdram? Is there more memory other than what I now about?
PM sent
