Replace drum unit for IR 2270
  • kayjaig
    • 144
    Please help with steps:
    How to replace drum unit for IR 2270
    Thanks.
  • welshman
    Technical Support Manager
    • Oct 2007
    • 91
    you should not be near a copier if cant replace the drum unit
    but
    open toner hopper door remove 1 screw
    left side remove screw near the front of copier
    remove front panel
    you will see drum
    open right side door
    remove dev racking screw and rack down
    remove drum screw take out drum and replace
    ohh removce toner bottle before above
    • kayjaig
      • 144
      thanks welshman
      the only canon tech for the company is out for vacation for 2 weeks. we have to take care his machines. thanks again.
      • AV8R
        Lurker
        • May 2008
        • 12
        Make sure you run DPC correction after, you don't want a dusty machine later.
