IR105 Error E000065-0000
  • cjsp
    • Jun 2025
    I'm not a tech. Any suggestions on a fix for a "dummy"?
  • shazza
    • Nov 2009
    • 96
    1 copy/print can be produced, though blank. If trying 2 or more E065 displayed after 1st blank output.This points to primary fault but corona is on and VDM is within spec.every time. Volume on m/c = 1.5 million. Relace black dev. to cure. FG6 8730 000
    Shazza
    • Oze
      Ricoh Fanboy
      • Jul 2008
      • 1663
      Time to call a tech...
      It may just be charge leaking involving the Primary Corona unit or as stated the developing unit may need to be refurbished or replaced.
      • SCREWTAPE
        East Coast Imaging
        • 3396
        Primary corona FG6-7313-040.
        Simple fix. But i would have a tech check it out.
        There other things that can cause E065, HVT PCB could be shot.
        Also if your drum is old.
