iRC3220 alarm-2 code
  • sgcopiertech
    • Aug 2025
    Hi, I've got an alarm code for iRC3220:
    EEFFFF - "000247"
    I guess it would have been very easy
    but the problem is - I cannot find this
    on my service manual (revision 00L)
    this is the only info I've got:
    EE - Alarm location code
    FFFF - Alarm code
    anybody got any info about this? maybe it's included
    on a newer service manual?
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Where are you looking when you see this alarm-2 code. Copier>Display>Alarm-2
    What is happening with the machine and what got you looking at the alarm codes.
    • sgcopiertech
      yes, Copier>Display>Alarm-2
      the machine print is misaligned + out of registration, so I serviced the ITB assembly, it got me nowhere so I tried changing the whole assembly with a working one but it gave me a misaligned print also. so the series of troubleshooting and other servicing began. I tried to check for error which may give me a hint on whats happening but I noticed that the message <ALARM> instead of <ready> so I went to see the alarm and found 000247, I was not sure what I was doing at the exact time he gave out the error but it may have been either I was performing L-ADJ-0 or doing auto-gradation adjustment.
      I tried to perform this two this morning but the ALARM didn't come out so it may not have been the case.
      other servicing I've done is:
      service SALT sensor
      reposition LASER
      reinstall system software + upgrade firmware
      changed 1 set of drum unit.
      so far print is still the same
      • SCREWTAPE
        East Coast Imaging
        • 3396
        service SALT sensor
        reposition LASER
        You have done much.
        Setting the lasers back to home position usually corrects this issue.
        When you updated system firmware did you up date DCCON.
        Maybe you have bad DC.
        • sgcopiertech
          When you updated system firmware did you up date DCCON.Maybe you have bad DC.
          yes, DCCON was included on the update. about the bad DC? would clear-DC con help?
          • SCREWTAPE
            East Coast Imaging
            • 3396
            You can try.
            Print out a P-print first before clearing ram on DC
            • sgcopiertech
              problem solved changed the DC board.thanks screwtape!
              • SCREWTAPE
                East Coast Imaging
                • 3396
                Nice. Happy to hear that your problem was solved.
                • Desert Rat
                  • May 2008
                  • 1089
                  I have run into the alarm code also, and came up with no definition.
                  I just happen to notice the alarm code. As a routine I will check the
                  date and codes of the last 4-5 jams if logged in recently to see if there
                  are a lot of the same codes.
                  I only have the first version also and have found other items in the
                  machine service mode that are not explalined in my manual. This is
                  very fustrating not getting all the answers.
                  I just clear the jam, alarm and error codes.
                  DR
