border light in canon ir 2016
  • bechir00011
    • 24
    hi,
    i have a canon ir 2016 , the copy is very light just in the border ( edge of 1cm or 2 cm in the paper broad) .ihave changed the toner , cleaned the developper part and the same problem
    can you help me please
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    try this ...
    hi friend bachir ..l have the same problems last month ..are you sure you add the original toner ?...if yes ..controler the roler charge up the drum ...try clraner that ...good luck
    Originally posted by bechir00011
    hi,
    BEST TECHNICIAN . NICE PEOPLE .
    • bineeshgeorge
      • Jul 2009
      • 107
      Hai,
      It may the problem of laser unit. You check the side of the mirror in the laser unit is soiled with toner, just check. Good luck.
      • bechir00011
        • 24
        no result
        Originally posted by bineeshgeorge
        Hai,
        i have tested the two solution but the same problem.
        i have remarqued that the distance between drum and developper roller is begger ,where the copie is light, than the other part of paper where the copy is good.
        when the drum is closed is not in here correct "attitude".
