can anyone tell me what the error code e061-0421 means
clc1000 codee e061-0421
more than likely you need to have a tech restart the developers and do a full PM on the machine for starters. With the E061 you could have dirt up in the drum cavity giving false readings, but your drums could be going bad as well.Accidents don't just happen. They must be carelessly planned.Comment
What are your qualifications to work on this copier?? You could easily dig a bigger hole for yourself than the one you are in now. My advice is to seek out a trained technician to accomplish this task."Once a King, always a King, but once a Knight is enough!"
the CLC-1000 is not a machine you want to take on without the proper information and parts. The assemblies are much different from a office printer. It would be money well spent to find a tech in your area who will help you and teach you how to service the machine.Accidents don't just happen. They must be carelessly planned.Comment
Ok I took everyones advice, I had a tech out, had a full cleaning done, and everything worked great for about a day .. now im getting the error e061-0422 now the tech got the same error when he turned it back on after cleaning it.. but he swapped something from the black drum to the blue... and it worked for him... But it sure didnt last. So what does that error mean? Any adviceComment
your drums are probably in need of replacement if he restrung the carona wires and the grids are in good shape.
The error code you are getting is for the black drum.
Did you watch the tech while he was working on the machine?
The CLC-1000 has issues with toner getting up in the potential sensors above the drums. If they were not cleaned and an EPC adjustment done in service mode that could cause the error to come back as well.Accidents don't just happen. They must be carelessly planned.Comment
