ir 105 code E00577-002
  • HaSSaN010
    hi....
    i have canon ir 105 ::: E00577-002
    There is an error when make my paper lengthwise,..,..,
  • charm5496
    • 2387
    Inspect the 24T / Gear 15T pully for a damaged tooth (see page Q20-1, key number 53 in Parts Catalog). If replacement is needed it will be necessary to replace both FS7-0355-020 and FS7-0356-020 as a set due to a design change.
    • HaSSaN010
      thank you
      Thank you for your answer on the subject
      But the problem comes with copies of a specific
      I mean, when copying the image height and not supply
      Note that there was a problem with hard drives and the problem went clean through the program code
      But now this code
      What is the solution????
      • charm5496
        • 2387
        But now this code
        Hassan,
        I have seen this error and I gave you the solution. The E577 has nothing to do to with the E602 which is a HDD issue. Do you not have any manuals on this model?
        • zaza
          MECANOGRAPHE
          • Mar 2008
          • 1095
          manuals free4you ...
          hello dear friend hassan and salam alykoum ..so if you need this service manuals ...l think you have my mail also my name in skype ...only follow me ..l have this service manuals ..but don't forget l sent you ..just free4you ..thx
          hi....
          BEST TECHNICIAN . NICE PEOPLE .
