This is driving me nuts. When I got to the customers I made some copies
off the glass. Looks ok. But when using the feeder it puts background
on the page. Try to light it up and it gets worse, then the density drops
but still have background.
Here's what I've done. Cleaned optics, both side of platen and scan
glass and mirrors.
Pulled the dv station it looks normal. I saw the toner band on the drum
so I pulled it and cleaned the erase lamp, cleaning blade, pot sensor &
cleaned the scum from the sides of the drum. There was not that much
scum on the drum and the chargers looked fairly clean. Only 37K on the
wires. The pre-transfer charger was dirty and causing small short pencil
thin lines from .25" to across the page.
I did a DC-Con clear and re-entered the values. Now it displays European
paper size and I have not found where to change it back. Although I
just read a post from screwtape for Waffu22 and that sounds like where
I need to go.
Also this machine came up with an E602-0003 code. I ran HD-check,
that seemed to take care of that. But the original problem remains.
I have had this code a couple of times on this unit. It only has 570K
copies.
I only have the first version of the IR5020 manual. I did get something
else but it only listed the different part numbers. That publication is
TP03 110.
Anyone got an answer for this problem?
I am thinking it has to be changing either the primary charge or the
dv bias. I hope it is not related to the E602 code. I am not able to
download or update firmware. I do not have that centronics cable.
If anyone has a suggestion it would be appreciated, this customer is
a printer.
DR
