canon ir 2025i e 000808
  • lightningjeremy
    • Jul 2009
    • 139
    i was trying to replace the fuser in a 2025i and ended up with error e808. the fuser is brand new oem. when i reinstalled the old one the machine functions fine. what am i overlooking? thanx
  • costd
    • Jan 2008
    • 409
    May not be much help, but a Canon TP says the E808 is related to not pluging one of the conectors in - or a bad controller board. Since it works with the old unit, I would try installing the new unit again and make sure the connector with the yellow and orange wires is seated.
    • SCREWTAPE
      East Coast Imaging
      • 3396
      The E808 is due to the thermistors. There's also a possibility that the fuser is defective. If the thermistors are bad the code will appear but will not reset until the fixing film assembly is replaced. Is it new?
      As for the connector. It is behind a cover on the side of the machine.
      Its a six pin connector with two yellow and two orange wires.
      The connector is to the thermistors.
      • lightningjeremy
        • Jul 2009
        • 139
        it is brand new oem
        • SCREWTAPE
          East Coast Imaging
          • 3396
          Check those connectors, check the pins. It really doesn't matter whether its new it could still be defective. You never know.
