Canon - Incoming Faxes To Email?
  • azppc
    • Jul 2025
    Does anyone know if a Canon Imagerunner 1025if will take incoming faxes and automatically forward them to an email account? I was told it would by a buddy but in messing around with a friends, I could not see anywhere w/in the UI where this was possible. Thanks!
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Yes. To setup Fax Forwarding you need to connect through the RUI of the imageRUNNER 1023iF. Select Additional Functions, then Forwarding Settings. You must have your address book set up. You can forward to a file folder or email. Just pick who you have in your address book.
    You must also have your SMTP info configured into your 1025iF, this is require for emailing. Otherwise you can have faxes forward to a file folder.
    • azppc
      Works... thanks so much!
      • SCREWTAPE
        East Coast Imaging
        • 3396
        No problem.But you did all the work so give yourself the pat on the back.
