irc 3220 vs 5185
  • smiley
    • Aug 2008
    • 616
    irc 3220 vs 5185
    hi guys i need help. what is ideal color copier for you if you are using heavy stock of paper between 3200 and 5185.
    there is no glory without sacrifice
  • charm5496
    • 2387
    either one will run heavy stock fine. The 5185 will not run glossy stock that well though.
    • SCREWTAPE
      East Coast Imaging
      • 3396
      It would have to be at least under 300gsm.
      • smiley
        • Aug 2008
        • 616
        yes but they used coated paper.can 5185 work good on this cause 3220 make bubbles on this papers.
        • Canuck
          Tech Specialist
          • 1713
          Spec on both machines is maximum 263 g/m2 i believe....about 10.5 point using caliper system. Canon will not support anything heavier run thru machine. I have customers that run 12 pt. but they know if they have a problem with 12 pt. don't call me. 3200 will run the heavier stock better
