GP605 print board rebooting
  • macuk
    • May 2009
    • 90
    Just put a different (2nd hand) print board in, has version 2.0 loaded but when printing using 2.0 driver prints one copy then reboots each time.]
    Any ideas?
    thanks
  • ymmtech
    • Jun 2009
    • 191
    1. Restore factory default.
    2. Still not OK ? Then reinstall printer firmware.
    • davidj7
      • 1107
      use PDL downloader and reinstall the software
      a machine is only as good as your tech : source:screwtape ; the scary one
      • ymmtech
        • Jun 2009
        • 191
        More then one way to solve HDD problem.
        Still can use cloning tool to fix HDD software if no no PDL downloader/printer firware/software.
        Me use cloning tools.
        • macuk
          • May 2009
          • 90
          gp605 rebooting
          Hi guys
          Have been back to customers and reformatted hdd and reloaded software to the board.
          the machine works fine via my laptop with crossover cable, but when i connect it back to customers network it reboots even when sending a test print from the driver. the customer is using exactly the same driver as on my laptop.
          if i clearthe jobs off the the print board and reboot, it comes back to ready. I have loaded drivers locally onto a number of pc's and also onto their server but no joy. Reconnect to laptop and it prints fine.
          Any ideas?
          Macuk
          • davidj7
            • 1107
            check if there is a clash of IP addresses
            • Herrmann
              • Jan 2006
              • 792
              do not use autonegotation, use solid transfer rate.
              If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
