Canon ir 3300 hdd formate installation
  • SANDIPVADALIYA
    • Aug 2025
    I want to know howto formate hdd and install it and what we requier for it, like hardaware side and software also and if any body have it plz send it me i need it most
    plz hellp me
    sandipvadaliya@gmail.com
  • bnmand
    • Sep 2008
    • 383
    You need a compatible hdd (replacement instructions are in the service manual) e.g. the ones canon sells to techs.
    You also need a IEEE1284 bi-centronics parallel cable (any one of these will do, will work with a parallel port set to ECP mode, ideally use Windows XP) or a nethawk cable (special canon usb-to-parallel cable, the only one that works with SST).
    You will also need the Service Support Tool (SST).
    You will also need the IR3300 firmware (same as IR2200). Note networked firmware is different and IR3300i (uses same firmware as IR2200i) uses different firmware again.
    Instructions for using SST are in the SST manual.
    If you have all those things, read the instructions in the manuals and post again if you have issues.
    • davidj7
      • 1107
      bnmand: he dosent have any but need all. I got a private message
      a machine is only as good as your tech : source:screwtape ; the scary one
      • ymmtech
        • Jun 2009
        • 190
        More then one way to fix HDD.
        SANDI, it is good to have all firmware/software as what bnmand mention.
        Even if you donn't have, using HDD cloning tools can do also.
        • SANDIPVADALIYA
          thanks
          hallo frnds
          thank u very much for give response me
          i'll try now and if i get any prob then i tell u
          thanks again
