6000 or 6020 or 6570
  • karanoberai21
    • May 2009
    • 44
    hi guys can somebody suggest me which machine i should take
    6000
    6020
    6570
    which one is better.
  • brianSTX
    • 12
    Canon segment 4 machines
    DEPENDS ON INTENDED USE (COPY, PRINT?, SCAN?)
    YOU LIST 3 GENERATIONS OF CANON SEG. 4 MACHINES (IN DESCENDING ORDER OF AGE).
    6000 - 60PPM EXCELLENT COPIER
    6020 - 60PPM EXCELLENT COPIER NEWER
    6570 - 65PPM EXCELLENT COPIER NEWER STILL MEAP AND UNIVERSAL SEND ENABLED INDUCTIVE HEATING INCREASES COST OF MAINTENANCE
    COST V. FEATURES
    • charm5496
      • 2387
      brian hit the nail on the head
      I enjoy working on the 6020 series more, but if you need the bells and whistles go with the 6570.
      The fuser on the 6570 does not last as long although we have found a LFR with pressed on bearings from Q2 that are working quite well for us.
      Beyond the fuser the machines are almost identical mechanically.
