canon ir 5570 help
  • hamdyyassin
    • 84
    canon ir 5570 help
    my copier canon ir 5570 does not work as a printer .
    i dont know if the porblem is the system or i need a printer kit .
    i need system software if the problem with it.
    thanks for help
  • charm5496
    • 2387
    push the counter check button and then hit device configuration. It should say UFR/PCL/PS in there.
    Or you can go to service mode copier>display>version and see if the boot rom is labeled as an 'N' version
