IR 6870 trouble with print server
  • lazo777
    • Jul 2025
    Hello everyone,This is my first post,but Im not here for the firs time.Some informations from this forum helped me a lot before. Im having problems with IR 6870. We used it with print server G1, and it only worked with one driver.Now we have problems in comunication betwen copier and print server.When I write ping command in my pc,print server replys,but when I try to contact it from copier i get "wait for a moment(check the power source of the print server behind the main unit and conection cable if the display doesnt change in a moment). Prin server is on and "00" is on the PS display, that means its working ok. What could be the problem? Can I run IR 6870 whithout print server? I tryed,but no luck.
  • Kapten
    • 52
    Turn off the m/c start the ripp wait 10 sec turn on mc.
    Wait 5 minutes and try to surf to m/c.
    If you cant surf to the rip you have to reinstall system.
    Its not possible to just skip the rip.
    You have to change a card and do some settings in s/m.
    Check if you can use rui.
    Just type in the ip adress or try with the port nr.
    It could be 8000 or 8080 eg. 192.168.1.10:8000
    Use the driver on the rip, instead.
    Reinstall the rip thats my advice.
    • lazo777
      This rip starts when you turn on the copier, I cant turnt it on by it self. Ill try to reinstall software on rip. Thanks Kapten
