Canon W8400 firmware help, with printhead error e02802!
  • jonbonse
    • Jun 2009
    • 737
    A customer of mine has printhead error E02802 on their W8400.
    They have replaced the printhead with a new one but still shows printhead error.
    I have tried to do some resets in service mode but no luck.
    I read there is a firmware update which could resolve this issue but the program 'Gero firmware update utility 3.0' simply wont find the printer installed on my system neither via USB or ethernet! I can print to it (or at least see it trying).
    I also understand that Canon ship the printheads out with the firmware but the customer seem to have binned the package the new printhead came in and didnt realise the firmware was there too.
    Can anyone forward me the firmware and update program which will enable me to update the firmware?
    All replies are very much appreciated!
  • teckat
    • 16083
    Follow this link below:
    Professional Large Format Inkjet Printers - Graphic Arts Printers - Corporate and CAD Printers - Large Format Software - PIXMA Corporate and Graphic Arts Printers - PIXMA Pro Professional Inkjet Printers - Photo Fun Projects - Large Format Printer -
    Canon USA Consumer Products
    • teckat
      • 16083
      1) Power off the Printer.
      2) Press and hold the INFORMATION + STOP + OK buttons simultaneously, then press the POWER button. Release the buttons when the message "FIRMWARE UPDATE" appears in the display.
      If Print Head is replaced without updating firmware, the machine will go into error. In order to bypass this error, CITS (800-423-2366), will ship the L-Printer Service tool CD upon request. This tool will override the error code and allow you to update firmware with the new Print Head.
      • jonbonse
        • Jun 2009
        • 737
        Thanks teckat
        So i need the L-printer service tool if the machine has already had the new printhead?
        What if I put the old printhead in that the fault originated with, could I use the firmware update tool downloaded from canon usa to update?
        or do i have to perform what you said above:
        '1) Power off the Printer.
        2) Press and hold the INFORMATION + STOP + OK buttons simultaneously, then press the POWER button. Release the buttons when the message "FIRMWARE UPDATE" appears in the display.'
        then use the downloaded firmware tool from canon usa?
        • teckat
          • 16083
          yes
          • jonbonse
            • Jun 2009
            • 737
            teckat
            Still no joy in updating the firmware on the W8400!!
            Tried the FUT downloaded from Canon and put the machine into downoad mode. . .
            Still the upgrade tool will not see the machine to upgrade!
            The only thing I havent tried is the parallel interface to see if it can upgrade that way.
            If you have anymore ideas, please let me know!
            Much appreciated!
            • teckat
              • 16083
              Originally posted by jonbonse
              teckat
              Much appreciated!
              (First, power off the printer)
              The heater board on the print head has been changed for manufacturing reasons.
              Before replacing the print head, please be sure to perform the firmware upgrade with the old print head
              installed.
              Following firmware version upgrades should be performed according to the model machine that you have.
              Firmware version
              W2200: V. 3.08
              W2200S: V. 1.08
              W6400PG: V. 2.15
              W6400D: V. 1.10
              W8400PG: V. 2.15
              W8400D: V. 1.10
              Updating the firmware
              <Windows>
              1. Turn the printer ON. Check that the printer is online.
              2. Run the file “setup.exe” in the “Firm Update” folder in the CD-ROM. The “GARO Firmware Update Tool”
              will be installed.
              3. Run GARO Firmware Update Tool from Programs in the Start menu.
              4. Now follow the instructions for upgrading the firmware.
              <Mac OS 8/ OS 9>
              2. Select the OS 8/ OS 9 folder in the Firm Update folder in the CD-ROM, and run “GARO Firm Update”.
              “GARO Firmware Update Tool” will be installed.
              3. Run “GARO Firmware Update Tool” from “Applications” – “GARO Firmware Update Tool” folder.
              <Mac OS X>
              2. Select the OSX folder in the Firm Update folder in the CD-ROM, and run “GARO Firm Update”.
              The “GARO Firmware Update Tool” will be installed.
              If you have an error code on the display please reinstall the old print head and use the “download mode” to
              update the firmware.
              How to enter the download mode
              W8400/6400
              While holding down the [Information] + [Stop] + [OK] keys simultaneously, turn the power ON.
              The Data LED will blink during downloading/writing procedure.
              W2200
              While holding down the [Utility] + [Setup] + [Reset] keys, turn the power ON
              [Firmware Update] will be displayed on the LCD display while the procedure is taking place.
              Precautions when performing the firmware upgrade.
              - Use the [GARO Firmware Update Tool] to confirm that the printer is online.
              - Do not turn off the power OFF while the firmware is being upgraded.
              - If the printer’s has the latest firmware version already installed, the printer’s status will display “Update
              Finished” when using [GARO Firmware Update Tool].
              • jonbonse
                • Jun 2009
                • 737
                thanks teckat but as I said before, the Garo update tool simply does not detect the printer is even there. . . evn tho you can send print jobs to it when it is 'online'.
                Even tried 'holding down the [Information] + [Stop] + [OK] keys simultaneously, turn the power ON to get into download mode.
                Still does not detect it is there.
                • teckat
                  • 16083
                  i do not know if u are a service dealer ?/ u can try 1 800 423 2366
                  Wide Format Printer support>
                  imageprograf w8400 >Canon CITS support group, located in Virginia,USA
                  • mailderrick
                    • Mar 2010
                    • 131
                    Re: Canon W8400 firmware help, with printhead error e02802!
                    What did you end up finding out? I am in a similar situation right now. I am trying to help a friend with their machine but they are far away and i do not want to make multiple trips. I have worked on many machines in the last 13 years but never thins model before. And we are a small printer shop so no access to canon support.
                    Derrick
                    • teckat
                      • 16083
                      Derrick
                      E2802
                      If a new Print Head is installed before upgrading the Firmware to at least 2.15, Error Code 2802 may occur. Instructions and the CD for updating the printer are included with the new print head, however, it sometimes gets overlooked by the customer.
                      Work Around:
                      Install the old (original) Print Head.
                      Degrade the firmware back to 2.11,using the L-Printer Service Tool, reboot the printer.
                      Upgrade the Firmware to 2.15 using the L-Printer Service Tool, reboot the printer.
                      Install a new Print Head, check the Nozzle Print pattern for misfires.
                      Perform appropriate adjustments.
                      • mailderrick
                        • Mar 2010
                        • 131
                        One more question. They were in the middle of setting this machine up and deleted the driver and scrubbed the mac to get ready to set it back up when it needed a printhead and waste tank installed. Now that i have to use the L printer tool to downgrade the firmware and re upgrade so i can install the new head...how can i even connect to the canon at this point.. do i have to go in through a local port or is there a way for me to pull the ip address off the macine so i can ping it or try to set up a driver(although i think the mac won't let you set up the driver at all til it is at ready)
                        • teckat
                          • 16083
                          The requirements for the L Printer Tool are:
                          1. The print driver must be installed on the PC or Laptop that is connected to the printer.
                          2. The FUT file must be downloaded and unzipped on the PC or Laptop that is connected to the printer.
                          3. The PC or Laptop needs to connect to the Printer, via the existing network configuration the customer is already using or a cross over Cat. 5 cable or a USB 2.0 cable.
                          Note: USB is simpler to use, (No TCP/IP configuration is needed).
                          L Printer Tool Version 1.50
                          When a problem on the printer occurs and an error code is displayed, effectively disabling the printer, this
                          service tool allows you to bypass the error and aid in troubleshooting. Under the above conditions, the
                          printer becomes disabled and cannot be flashed with firmware using the traditional methods.
                          which allows you to update the printer with firmware. This L Printer Tool also allows you to retrieve Status Print and Print inf files which allows you to better evaluate certain problems.
                          see pdf>>>>>>>>>>>>>>>>>>>>>>>>>L Printer Tool.pdf
                          To flash/upgrade system software on the Large format printers the FUT file for the model must be downloaded. This FUT program contains the firmware to flash the printer. The L Printer tool needs this firmware to flash the printer.
                          Canon U.S.A. : Support & Drivers : imagePROGRAF W8400
                          1- select the FUT file to download
                          2-select where to save the file on the HDD. The best method would be to create a folder and save the file in the newly created folder.
                          3-select save and the file will start to download.
                          4-file that was just downloaded is in a zipped format and needs to be unzipped or extracted so it can be used.
                          Double click on the zipped file and the Win Zip Self-Extractor will open as in the image below. Now select [OK].
                          5-after the file has been unzipped the Firmware update tool is ready to install and use or the firmware files are ready to be selected and used by the L Printer Tool.
                          6-when the L Printer tool is used the program needs to select the path to the [.jdl] file that is actually the firmware file.
                          C:\Large Format Printer\Firmware files\
                          Now the the [jdl] file can be found & the L Printer tool is ready to use this file.
                          • mailderrick
                            • Mar 2010
                            • 131
                            got it although one thing looks incorrect(or maybe i am wrong) it says if the new printhead is installed then to install l printer tool and downgrade..but what if the new printhead was installed and you get the same error (or an error) but the firmware was not upgraded. Is it still necessary to install L printer tool to "downgrade first" if it was not upgraded or can one simply put the old printhead back in and thruogh L Printer tools just upgrade and move forward fromt here?
                            • teckat
                              • 16083
                              Canon never explains things correct/u need to experiment most of the time-
                              not sure if I would try the upgrade with the old print head
                              put in the old head/ run the printer tool/see if u can downgrade/ ?
                              if u can > u may be on the road to success
