parallel to usb
+ More Options
Posts
  • bomberi
    • 107
    parallel to usb
    My thanks to you, the last days i have change my laptop to another that have not parrallel connect and I want to use parrallel to usb to download software to ir 2200 so i take the way for sst manuel, at the final a windows that the file can not found in crogramfile/sevsuptool/inf/usbadp. i want help to config the cable.
  • bnmand
    • Sep 2008
    • 383
    You can't just use any usb to parallel cable. You need to use a nethawk cable (special usb to parallel cable designed for use with SST). It's the only cable that works.
    • bomberi
      • 107
      is that i say, i want to know how to config the nethawk cable.
      • davidj7
        • 1107
        if you have a PCMCIA slot you can buy those parallele port adapters otherwise you have to shell out around $150 or so for the cable
        a machine is only as good as your tech : source:screwtape ; the scary one
        • mrfixit51
          Lead Service Technician
          • Oct 2008
          • 1975
          The driver for that Nethawk cable is part of the PDL Downloader installer that is acquired from Canon.
          • SCREWTAPE
            East Coast Imaging
            • 3396
            By default you can find the driver in your Canon\ServiceSupportTool\inf\USBPAdp. You can install the driver by using the Windows Device Manager under USB controllers.
            • mrfixit51
              • Oct 2008
              • 1975
              Ya' learn something everyday,,, I did not know that! Thanks Screwtape...
              • SCREWTAPE
                East Coast Imaging
                • 3396
                No problem buddy.
