IR C3200 Hard Drive Failure
  • mncopyguy
    • Jun 2025
    Hi I need to know what types of hard drives I can stick in an IR C3200 I have the SST and the firmware and I have seen posts stating to a degree how to change the hard drive requriements on the SST software for loading a different hard drive but I need to know the coding for a different hard drive and which one to pick up at the local pc store.
    Thanks for your help
  • nivssluck
    • May 2008
    • 228
    You can use Seagate, Maxtor or any model with 20gb and above. If the HDD model # is not listed on the .ift file you will encounter an error on the SST with the HDD model # listed on it. All you have to do is to edit the .ift file on notepad (if you know where to find it) search the model of the HDD then copy the code on the next line then change the HDD model # with the new one then save.
    • lochuy
      • 10
      IRC3200 SST download fail
      Hi all,
      I used SST try to download firmware to my irc3200, half way it pop up error code 124.
      Someone know what is problem? Please Help.
      Thank you!
      • teckat
        • 16083
        Originally posted by lochuy
        Hi all,
        Thank you!
        that is an internal error/ make sure u have only one version of the SST on your Laptop
        make sure u select correct firmware for your 3200- is it a C or N boot rom
        if u have no Fiery on back u have the N boot rom with Multi Pdl Kit
        • SCREWTAPE
          East Coast Imaging
          • 3396
          Hi all,
          Thank you!
          First ?
          Why are you flashing the 3200?
          What version of SST are you using?
          It could be the HDD.
          A little tip. The SST can distinguish between N and C When flashing the 3200.
          • lochuy
            • 10
            I bought it but no HDD.
            I am using SST 4.22
            What is N or C?
            Thank You
            • SCREWTAPE
              East Coast Imaging
              • 3396
              N: Network printer.
              C: Stand alone copier.
              You bought it but no HDD???
              I don't understand?
              Are you a Tech?
              • lochuy
                • 10
                No, I am not a tech.
                I am trying to boot it up.
                Please, Help.
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  My friend, get a professional tech to check this out for you. You can cause more harm.
                  If your having booting up issues. Many things can cause this type of problem.
                  • teckat
                    • 16083
                    Originally posted by SCREWTAPE
                    First ?
                    SCREWTAPE> your thinking of the 3220 / on the 3200 u have to choose N or C
                    • mrfixit51
                      Lead Service Technician
                      • Oct 2008
                      • 1975
                      I am using SST 4.22
                      What is N or C?
                      If I understand you, you bought this copier without a hard drive?? What make/model of hard drive are you attempting to load system software to?
                      • SCREWTAPE
                        East Coast Imaging
                        • 3396
                        Originally posted by teckat
                        [/COLOR][/B][/COLOR]
                        You might be correct.
                        Its been a while since I've even seen a 3200.
                        Thanks for the refresh.
                        • lochuy
                          • 10
                          I am attempting a Maxtor 6E040L0, 40g.
                          Is it ok?
                          • charm5496
                            • 2387
                            On the 3200/3220 series you can get into the (IFT) and put that Maxtor serial number in that file. If you need instructions just do a search for it in this forum.
                            • Tajudeen
                              • Jan 2015
                              • 5
                              Re: IR C3200 Hard Drive Failure
                              Hi Guys,
                              I have this CLC 3200 which is coming up with an error E000602-0901, and is pointing to the HDD.
                              I really don't know what to do.... Please help me....!!!!
                              Regards.
