Additional Functions
2 & 8 together
You are now in level 1 of service mode
To get to 2nd level, press 2 then Additional Functions.
Then do as Screwtape & MacW instructed. Highlight the item you want to change. Enter the value then press the OK key in the display to make the change.
If you are not trained on this copier, use these instructions at your own risk. And don't change ANYTHING else! Power copier off/on for the changes to take affect
Reason: my shitty grammar
2 & 8 together
