Canon IR HDD
  • Hejsan
    Uhu
    • Mar 2008
    • 42
    #31
    iR3300 HDD
    Thanks guys! First, I'll try Low Level Format... Hope, it helps
    • davidj7
      • 1107
      #32
      Hi guys i am having a similar kind of problem with 8500. I need more space in the mailbox.But i am able to use the only limited space provided by Canon.is it possible to install a 80Gb or higher HDD in 8500 and use all the space.
      a machine is only as good as your tech : source:screwtape ; the scary one
      • bnmand
        • Sep 2008
        • 383
        #33
        I doubt it. Why would you need more than 80gb anyway? If you need more and its networked, put a computer next to it and store documents on that.
        • haydar64
          #34
          u can use ABBY FINE READER for scanning all documents.
          i'm using it, and i can convert to word-excel files , .pdf files.
          you have to try man.
          • davidj7
            • 1107
            #35
            haydar this is a stand alone machine located in a remote location . In office i am already using the option u suggested.Thanks anyway
            • rosaro75
              • Mar 2009
              • 86
              #36
              hai everybody don't go costly. buy any ide hdd any brand in any size more then 6gb. send me the hdd brand name and model no.detail. i will send you a hd format file. just replace it in your 2200 hd format folder. you see the unbelivable thing. those who interested send mail and enjoy. also for any model machine.
              • pearlpdy
                • Jul 2008
                • 44
                #37
                hd format file need
                sir, pls send me hdd format file for all model and all type of hdd my mail addr is pearlpdy@yahoo.com
                thanks for ur coperate
                • rosaro75
                  • Mar 2009
                  • 86
                  #38
                  hay i altered 3300 to use 3.5'' hdd that is bigger one.mfc board had provision to put a connecter for 3.5'' hdd ide cable. and i took 12v power for hdd from orange color wire which is almost dummy in mfc board box. and normal 5v from mfc board. i am sorry.i sold the machine. or i will show the photo
                  • mtech
                    • Mar 2007
                    • 307
                    #39
                    I would think that if you needed 20G max, you could use a larger HDD and partition off 20G marking it primary/active and leave the extra space unallocated. Then load the system software onto the 20G partition. Never tried it though.
                    • T911
                      • Jun 2007
                      • 628
                      #40
                      can anyone provide us with the latest software here for the ir5000 hdd. it would be greatly appreciated since i had 3 last month crash and burn. thanks t
                      • cdvidaceiba
                        • 80
                        #41
                        hi , this is my "problem" with canon HDD
                        got some ir5000 ( c , n , dn , d ) and i want to make some back up hard disks , i got the same brand and model ( samsumg SV2001H) hard disk the machinne i am using has ... i had tried SST and gimme and error 150 that my disk is not valid .
                        i had tried to clone the hard disk and when i connect the cloned disk to the copier gimme and e602-001 ...
                        what can you recomend me to do
                        why if i got the same hard disk the SSt gimme that error code 150 and says that my hard disk is not valid
                        what hard disk you can recomend me for this model ir5000/5020 copiers
                        thanks in advance
                        • cdvidaceiba
                          • 80
                          #42
                          ok i already found the "problem or my problem " i am using one of the first versions of HD format file , that just have fujitsu and quantum drives on it , anyone can provide me the latest system software for canon ir5000/ir5000c copiers
                          what i dont understand is why my cloned disk didint work....
                          • rosaro75
                            • Mar 2009
                            • 86
                            #43
                            some clone tools makes partition copy. so the mbr will not copied. so you have to use sectorwise copying tool.that means disk to disk clone mode tool.
                            if you want to format using sst. just send me the hd format file to me. i edit it and send you. it must work
                            • cdvidaceiba
                              • 80
                              #44
                              it works ,thanks Rosaro!!!!
                              • bariseryener
                                #45
                                Re: Canon IR HDD
                                Hi Guys,
                                I Buy IR3225N and havent HDD. Connections is SATA. What can i do? I found SST but i am looking firmware or Disc Clone Image. Anybody can help to me
