Instead of SST
+ More Options
Posts
  • adel_nassan
    • May 2008
    • 21
    Instead of SST
    hi every body
    IS there any program you are using instead of SSt?????
    i heared about one like Acronis or some thing like that
    if there are any one could you email it
    thanks
    adel_nassan@hotmail.com
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    The problem with using cloning software is that you have to find an exact match copier wise to get your "donor" image. You have to inconvenience another customer to get the image for your problem copier. If there is any corrupt data in the donor image, it is passed onto the cloned drive. SST is the best way to service these copiers. You get a clean system as a result. You can google to find places you could download Acronis.
    • remielee
      Technical Analyst
      • Mar 2010
      • 140
      what is the procedure of hdd cloning? i mean instruction on how to use the cloning? do i need to make the working hdd as slave in the computer and copy all the files inside and put to my computer then after that put the new hdd slave it and copy the files from the source hdd that i copied on my computer. is that all or needed to have a software for cloning hdd?
      • bnmand
        • Sep 2008
        • 383
        You need software that will clone at the block level. The clone needs to be an exact copy of the original and the data probably can't be read by your PC anyway.
        I'd recommend using SST though like mrfixit51. Finding a copier that is an exact match, both in model number and in terms of options installed, is able to be taken offline (not inconvenience customer) at short notice and that has a hard drive in perfect working condition i.e. no corrupt data, may be very difficult.
        Some people clone hdds after setting them up using SST, but that does mean the customer's machine is offline for longer.
        • davidj7
          • 1107
          bnmand I have copies of hard disk all machines cloned in my laptop so its easy for me and sometimes depending on the model I dont even need to remove the HDD from the MFC. Its quiet easy for me compared to SST cause i learned clonning first, using SST later.
          a machine is only as good as your tech : source:screwtape ; the scary one
          • teckat
            • 16083
            Originally posted by adel_nassan
            hi every body
            thanks
            limiter experience/ stay with SST/ play it safe
            • bnmand
              • Sep 2008
              • 383
              Interesting. You store images of the hard disk in your laptop? I didn't realise that was possible. What MFCs can you restore a clone onto whilst leaving the hard drive in the MFC?
              • teckat
                • 16083
                sounds like trouble to me, stick with SST
                • davidj7
                  • 1107
                  most of the machines where i can plug the usb to ide laptop HDD converter. IDE desktop hdd is also possible but the there is external power involved so i generally remove it from mfc
                  • ymmtech
                    • Jun 2009
                    • 190
                    The size of HDD image for 3300 is 40MB, 80MB for 2220i.
                    • remielee
                      Technical Analyst
                      • Mar 2010
                      • 140
                      Sir steps and instruction using sst for the machne ir 5000 since dis machne have no usb port, thanx in advance i rather to use sst dan to clone prevention is better dan cure.
                      • bnmand
                        • Sep 2008
                        • 383
                        Steps and instructions are in the SST manual.
                        • mrfixit51
                          • Oct 2008
                          • 1975
                          This may be of some help to you, or like bnmand offered, reading the manual for SST will instruct you in it's use.
                          http://www.copytechnet.com/forums/ca...tml#post131783
                          • CanoNiR
                            • 50
                            If you make a clone with a working machine, can you get the mailboxes and address book?
                            Experience is the best adviser!
                            • remielee
                              Technical Analyst
                              • Mar 2010
                              • 140
                              thanx for the reply guys anyway i already read the manuls it was included on the SST software theres a steps on how to use the SST TOOLS. again thanx a lot godbless you guys!!!
                              thnx mrfixit51 for the response message too!!!
